Property Node to duplicate XY Graph Y Scale?
Hey Guys,
I have been struggling here looking for a property node to Duplicate the Y Axis on an XY Graph. I want to dynamically create multiple Y Scales and Y Axis but I can't find the bugger on the property node. Currently I've hardcoded and duplicated a bunch of Y scales and just making them invisible to start and dynamically making visible depending on input.. but this obviously is not extendable. Any help would be appreciated, thanks!
CLD | CTD
(6,988 Views)
Accepted by topic author ChrisK88
Hi Guy,
That's the way to go.
You cannot create new scales dynamically…
(6,975 Views)
Thanks GerdW,
That's quite aggravating, suppose I'll put this in the Idea Exchange to see if it gets any kudos..
CLD | CTD
(6,971 Views)
Someone posted here similar to what you are checking. Check if it is useful : http://forums.ni.com/t5/LabVIEW/Programmatically-add-multiple-scales-to-graph/m-p/698511/highlight/t...
Edit: i was checking for adding multiple scales programatcially but not duplicates. See if it helps, else ignore.
uday
(6,968 Views)
udka,
Thanks, but as I wrote in my original question, what you suggested is how I did it, and I don't like that method, it's not extendable.
If anyone thinks that there should be a way to do this programatically, please take a look at my submission:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-Invoke-Node-or-Property-Node-to-quot-Duplicate-Sca...
CLD | CTD
(6,960 Views)
