Property node for XNET session throws session invalid error -1074384864 for session define in project
I am trying to something very simple. I have and XNET session control on my front panel that is connected to a session property node. When I run the VI and select a session that is defined in my project, I get an error -1074384864 with the following explanation...NI-XNET: (Hex 0xBFF63020) An invalid reference has been passed to a NI-XNET session function. Solution: Only pass reference retrieved from Create Session, or from an IO name of a session in LabVIEW project.
  • The session is set up as "Single Input (Single Point)"
  • I have signals defined in the session list
  • The XNET database exists and is being read from by the session correctly
  • I don't have a hardware interface, but have left the "Interface" box empty and have put in "NA"
  • I've tried the "Frames" property and the "Mode" property and saw the same result
  • I tried an example from NIs "NI-XNET CAN Session.lvproj" and received a similar message XNET Read (Signal Single-point).vi...NI-XNET: (Hex 0xBFF63020) An invalid reference has been passed to a NI-XNET session function. Solution: Only pass reference retrieved from Create Session, or from an IO name of a session in LabVIEW project.
Any ideas?
(1,745 Views)
Accepted by topic author M_S_C
The issue was that I did not have a physical device connected and configured in the session.
(1,704 Views)
