Property node for numeric control change
I have a numeric control on my front panel.  I want to do something (write that number out to a gpib instrument) ONLY when it changes.
I was hoping the numeric control would have a bolean property node that would be true only when an increment or decrement button was pushed.
I've done it before with a loop tunnel and comparing the present numeric value with what it was the last time, but that is cumbersome and not very efficient, I'm sure...
THanks
(3,485 Views)
Use an event structure and you can use the "Value change" event.
Alternatively, you can use the OpenG libraries. It has a little VI that spits out a Boolean to indicate if a value has changed.
(3,483 Views)
Hey JLH99,
I agree with smercurio_fc, an event structure is a good choice. This allows your program to sit idle until the even of a value change occurs, at which point you will be able to move on with the rest of your program. Check out this Tutorial for a little more information on event structures.
Hope this helps.
-Ben
WaterlooLabs
(3,454 Views)
