Property node: invalid property
I want to set property of DAQmx channel. But there is an error said 'The property node has one or more invalid properties or uninitialized property items'. From https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MPKSA2&l=en-US, I should right click the property and choose Select Filter to configure it. But I did not find Select Filter. I used 2012 SP1 with DAQmx 18.0 under Windows10. In another Windows7 computer with 2012SP1 and DAQmx 18.0, I could find Select Filter. Thanks!
Message 1 of 1
(1,243 Views)
