Property node is not functioning in PXI RT
The property nodes are not functioning properly in my PXI RT system. When i keep a probe at the property node i see no values(all data types)
(3,221 Views)
You are correct!
I was suprised when I first discovered that complcation of RT.
I am not part of NI so I do not know the full inside story but I will share my undstanding.
The property nodes execute in the UI thread. Bad for determinism.
The FP get stripped when the code is targeted, so no objects to act on.
I have managed to work around this detail in all of my RT apps.
The only sticky point had to do with having to translate a enum value to its associated string becuase I could not read the enum's strings. Even that can be handled by flattening the enum to a string and parsing.
Please feel free to post regarding what problems this causes and we may be able to help.
Always interested in the limits of my world,
Ben
(3,212 Views)
