Property node label alignment problem
Hi all, can someone please help and explain why all of a sudden i have a problem when pasting a property node down onto my block diagram.
The label is no longer vertically compressed with the node itself and i have to manually move it each time.
Please see the attached screenshot as an example of this problem.
Thanks for any help,
Grant
(4,702 Views)
In addition to my original post, i believe the problem is due to the fact that i have used a carriage return in the control text label.  Therefore creating a double line name.  But i still dont know how to fix this glitch and have alot of property node to create.
(4,689 Views)
That is odd behavior, and I think it bears looking into to determine if it's a real bug.
As for suggestions for you: Use the control's caption for all that information, rather than making a label like that. Keep the label for the control simple, and you can make the caption whatever you want.
(4,687 Views)
Hey Guys,
I am able to replicate this issue, as shown in the following screencap.
I agree that this seems to be a bug - not a show stopper by any means, but if NI is able to resolve the issue then that is exactly what we should do. I have created a corrective action request with our R&D deprtment. If you want to follow this up with a product suggestion, please fel free to do so via the following link.
Product Suggestion Center...
http://digital.ni.com/applications/psc.nsf/default?openform
I do believe that Sercurio has offerred some great advice regarding the use of captions. The idea is that you should keep short, concise decriptions in the owned lables; then make the captions as desriptive as required.
The added benefit is that ONLY labels appear on the block diagram - so the graphical source code is not clutterred up with lengthy captions. Win Win!
Thanks for your time guys,
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(4,651 Views)
Can you please post the CAR here.
Mathan
(4,646 Views)
No problem at all....
Corrective Action Request - #198546
Rich Roberts
(4,622 Views)
