Property node of duplicate scales on waveform chart
I have duplicated a scale on my waveform chart so i can display two sets of data on two different scales. How do i get to the propery node of the duplicated scale so i can set the scale of it via my program when it is running. I will also add other scales to this graph that will need scaling in the same way. When i go to the propery node of the chart the only scale i can set via this is the original one. and not the duplicate scale.
Any help would be appreciateted.
(3,035 Views)
In the waveform chart's property node, you'll need to specify "Active Y Scale" first before you access the "Y Scale" property. "Active Y Scale" is the index of the Y scales you wanna modify. If you only have 2 scales, try setting it 0 and 1, and you should get different properties out of Y Scale.
Dan
(3,035 Views)
Cheers thats exactly what i wanted.
(3,035 Views)
