Property node
Can we use property node to pass data between two VI's?
(2,945 Views)
Yes.
(But there are better ways...)
(2,924 Views)
Instead of using property node directly you can use direct wire terminal (through VI connector pane terminals).
Save your VI memory usage!
(2,917 Views)
