Property to set hex/binary/decimal format at run time?
Hi, I'd like to allow my user to choose between hex/binary/decimal formats in his number input. I'm happy to do the radio button stuff and the code to "hear" what he wants, but I can't find a property of my variable which selects the format at run-time - there is of course the "Format & Precision..." which I can get at by right mouse click BEFORE running, so I know it's likely to be available at run-time. Any suggestions welcome. Thanks, Richard.
(3,021 Views)
Richard,
It might not seem ideal, but you could have the user enter data into a general text box, then the user selects which mode it is (hex, bin, dec), and then a set of Cases processes accordingly using "Format & Precision", etc.
Or, the user first selects which mode, which causes the appropriate control entry box to become visible and the others are hidden.
Lots of options... Good luck with it, Doug
(3,021 Views)
It's not necessary to use property node because you can use the builtin
property of the indicator.
Click the rigth mouse button over the indicator and select show radix.
On the left side of the indicator appear radix that you can push to choose
between hex, binary, octal and decimal.
Bye
Golzio
"R" ha scritto nel messaggio
news:50650000000800000058350000-1007855737000@exchange.ni.com...
> BEFORE run
(3,021 Views)
Use the Format & Precision>>Format property in a property node. See the attached file.
Brian
(3,021 Views)
The numeric properties list both the format and precision. You should
be able to do what you want with that. Read the radio button setting,
select the format and write to the property node for format.
Greg McKaskle
(3,021 Views)
