Propery Node for 'ENUM' control
Hi everyone,
I got some problems on figure out the property 'NumItem' for enum control with property node.
 I am trying to use that property to control the iterations for a 'For loop'.
Here is the link related: http://forums.ni.com/ni/board/message?board.id=170&message.id=400341&query.id=479803#M400341
Thanks for jmcbee.
the problem I am having is that I failed to find Property 'NumItem' there, either could I found some possible properties instead of it.
I be graceful if anyone of you could give me some idea,
PS: I am using Labview 8.6.
Thanks in advance,
-Kunsheng
(3,353 Views)
Accepted by topic author Kunsheng Chen
'NumItem' is the shorthand for 'Number of Items'. Look for that.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,345 Views)
Left-click on the property node and select "Number of Items" in the popup menu.
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
(3,344 Views)
