Prototype SMT Reflow Oven Controller
I am using the 'Prototype SMT Reflow Oven Controller' that I received through www.stencilsunlimited.com and can also be found on www.articulationllc.com I would like to use labview to monitor/record temperature (serial port) that is returned from the oven thermocoupler but haven't had any luck with it or hyperterminal.  I was hopeing that someone has used this item before and perhaps written some LV code for it.
(3,098 Views)
Did you set up Hyperterminal as below?
The serial protocol is 9600 baud, 1 start bit, 8 data bits, 1 stop bit, and no parity
(3,094 Views)
