Proxy setting in HTTP client
I am performing some HTTP requests to a web server using the HTTP client VIs.
The vi which is made to perform the aforementioned action works fine from a PC (say PC1) connected to a network (say network 1)  for which I dont give any proxy settings in internet explorer.
But the same vi does not work in another PC (say PC2) connected to network 2. The Response says 'network is doen or unreachable' I figured out the reason. The network 2 needs proxy settings in internet explorer settings but I am not using any such in my code in LabVIEW to reach the server.
How do I give the proxy settings in LabVIEW? I am not using Basic TCP/IP  to act as HTTP client rather I am using the HTTP client vis which comes inbuilt in LabVIEW 2012.
(6,554 Views)
Try the solution from this post: https://forums.ni.com/t5/LabVIEW/http-through-proxy-connection/td-p/995656
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(6,292 Views)
Please accept my apologies, I see that the theme of the old, but for some reason I have such a scheme does not pass. Could it be due to my proxy service provider (advanced.name), or an error on my computer?
(5,824 Views)
