PseudoInverse Matrix Glitch
until Christian brings the "ultimate" improvement I just "clean up" a little bit:
Message 11 of 15
(1,176 Views)
Yes, I actually did the same thing. Not sure why we need option "full" for the SVD. Same result (I did not check if the algorithm is sound ;)):
Personally, I would probably go over all diagonal elements and handle values close to zero differently.
Message 12 of 15
(1,172 Views)
Here's how that could look like (I think the elements of S are always nonnegative, but please verify).
The tolerance can be computed based on the elements and machine epsilon, e.g. as described here)
Message 13 of 15
(1,167 Views)
On a side note, you can of course operate on the vector S instead of matrix S. Maybe more efficient. (not tested).
I am sure things could be further optimized....
Message 14 of 15
(1,155 Views)
For what its worth I can replicate the original problem on a cRIO (VM) in LabVIEW 2020. Certainly looks like a bug in their RT Linux implementation. Interestingly when I tried it on a Linux desktop it didn't replicate - but I only had LabVIEW 2019 available.
It would be worth sharing your original code with NI through a service request at http://ni.com/ask so they can record it as a LabVIEW bug and hopefully fix it going forward.
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
Message 15 of 15
(1,094 Views)
