Psychrometric function
Does anybody know were can I find a VI that aplies the "psycrometric
function" to measure relative humidity by the use of a dry and a wet Pt100?
(3,007 Views)
Hi Luis,
check this link (http://www.bae.uky.edu/~gates/psych/psych.htm) ... even if no VI, you can find some C sources and use a CIN to integrate them.
good luck
(3,006 Views)
Luis,
There may be some helpful resources for you on the web. I searched at www.google.com for "psychrometric labview" (without the quotes) and found several hits, mostly from companies (and universities) that had used LabVIEW in their psychrometric applications. You may want to see if any of these links prove to be helpful.
Good luck with your application, and have a pleasant weekend.
Sincerely,
Darren N.
(3,006 Views)
