PtByPt Filter: can't change parameters dynamically
In my VI I use PtByPt Low-Pass filter.
Surprisingly, the filter parameters (e.g. cutoff frequency, order) cannot be change dynamically ... i.e. when VI is running.
I order to new parameters be taken into account I should restart VI.
Is it correct behavior for PtByPt filter ?
Thanks.
(3,398 Views)
Accepted by topic author Pavel_47
After changing the parameters, did you set the 'initalise?' to true so the VI can reinitialise?
(blog)
(3,389 Views)
You mean "initialize" input of filter ?
(3,382 Views)
Ok, I see.
Actually I've put button and it works: parameter are taken into account after button action.
But it's not very comfortably, I will try process it in the event loop.
(3,373 Views)
