Publishing a VI front panel
Hi to all.
I am trying to publish VI front panel using Web server. And with "Web publishing tool" it works well.
But when I compile my application all goes bed.
My main VI looks like this:
VI
1. In "Web publishing tool" I configured the "1.vi" to publish. (I see it in browser when it's opened)
2. In build spesification options I deselect checkbox "Remove front panel" to "1.vi"
3. I think there is something I miss.
My config files looks like this:
Main.ini
[Main]
server.app.propertiesEnabled=True
server.ole.enabled=True
server.tcp.paranoid=True
server.tcp.serviceName="My Computer/VI Server"
server.vi.callsEnabled=True
server.vi.propertiesEnabled=True
WebServer.TcpAccess="c+*"
WebServer.ViAccess="+*"
WebServer.Enabled=True
DebugServerEnabled=False
DebugServerWaitOnLaunch=False
niwebserver.conf
# Web server configuration file.
# Generated by LabVIEW 17.0.1
# 25.03.2020 12:06:17
# Global Directives
NI.AddLVRouteVars
ErrorLog "$LVSERVER_ROOT/logs/error.log", level=2, anew
AccessLog "/Program Files (x86)/National Instruments/LabVIEW 2017/resource/webserver/logs/error.log", anew
TypesConfig "$LVSERVER_ROOT/mime.types"
LimitWorkers 10
LoadModulePath "$LVSERVER_ROOT/..;$LVSERVER_ROOT/modules;$LVSERVER_ROOT/LVModules"
LoadModule LVAuth lvauthmodule
LoadModule LVSnapshot lvsnapshotmodule
LoadModule LVRFP lvrfpmodule
Listen 80
# Directives that apply to the default server
NI.ServerName LabVIEW
DocumentRoot "C:/Program Files (x86)/National Instruments/LabVIEW 2017/resource/webserver/../../www"
InactivityTimeout 60
SetConnector netConnector
AddHandler LVAuth
AddHandler LVSnapshot snap
AddHandler LVRFP
AddHandler fileHandler ""
AddOutputFilter chunkFilter
DirectoryIndex index.html
(3,065 Views)
How does it go bed (bad 😎)?
What do you expect and what do you get?
This could be anything.
My first guess would be a firewall blocking the application, while LabVIEW has access through it. Disable the firewall to check. If it helps, enable it again, and add the exe to the allowed application..
(3,015 Views)
Accepted by wiebe@CARYA
Thank you for answer.
I have solved all.
I open up some features:
1. Web server options in development system not influence on compiled application. (so we need to configure it in application). I think if we don't wire webserver config file - it will ignore all options in Application.ini file.
2. VI in project has a different path compare with simple VI
3. Compiled application when open VIs by reference, open it in development system if labview is running. (not in runtime)
(2,964 Views)
