Publising front panels of not visible subvis on the web
High
my main program has tab object with 10 pages. Within the main program there are several subvis whose front panels i want to publish on the web.
The front panels of these subvis are not visible in the main program.  Front panels of some subvis are displayed correctly in browser (IE, Firefox) but some not.
Fields of the object are empty or their fields are not refresh with new data (att. pict " array indicators").
The problem is worse if not visible subvi contains chart object. In the browser window data are moved out of the chart window (att. pict. "chart within...").
For monitoring front panels of the subvis i use MONITOR mode of the LabVIEW web server.
Any idea, hints or simple example is welcome.
Thanks and regards
Trajan
(2,536 Views)
Duplicate post!
(2,522 Views)
