Pulse-Counter to RPM using Digital Inputs from a DAQ Device
Hi all, Please help me with the following. I know my program is terrible but I am learning a bit, so I welcome all the recommendations and improvements.
I am trying to convert a speed sensor digital reading into an RPM. The speed sensor is mounted in a transmission Gearbox and reads Gear Teeth (24) and blinks with each passing tooth.
Using the Pulse to RPM Formula for converting the teeth readings or Pulses, I can work out the RPM of the rotating Gear.
I have upload my Arduino code as well for Blink code that simulate the blinks that the sensor would make e.g. voltage high/low with a delay in between. This can be adjusted to reflect difference pulse frequency. The attached example translate to a 5 Hz pulse equating to a 12.5 RPM speed for 24 gear tooth blinks.
Issues:
  • My RPM readings fluctuate and I need them accurate to the rotation speed of the shaft.
  • I want increase my read rate to 10 readings per second in order to get a faster reading up changing speed of the shaft. (I can set the time elapsed to 0.1 s).
Device: NI USB 6002.
I appreciate all the input I get from everyone. Thank you.
Message 1 of 1
(3,142 Views)
