Pulse train on 6024E, Labview (PC)
I was wondering if it's possible to change
the output frequency (GPCTR0) without the
output going low for a few milliseconds.
I am using the 'pulse config' and 'counter start'
vi when I need to change the frequency. I plan
to use this setup to calibrate speedometers and
tachs. It would be nice if I could stop the needle
from trying to jump to zero every time I have to
change the drive frequency.
Somewhere in the manuals is mentioned that the
parameters of the DAQ-STC can be changed 'seamlessly'.
I tried (in vain) finding this section again.
Any advice would be welcome.
thanks,
Walter
(3,699 Views)
Walter,
I'm not 100% sure if this example will eliminate the dead spot during
counter reconfiguration or not, but I think it might:
http://digital.ni.com/explprog.nsf/websearch/b679344977a79f708625675100466034
("Pulse Width Modulator for LabVIEW" on the NI example programs site)
It should work with your E Series card.
John Lum
(3,699 Views)
Thanks John,
I hope to try it today. Will let you know how it
goes.
Walter
John Lum wrote:
> Walter,
> Regards,
> John Lum
> National Instruments
> > to use this setup t
(3,699 Views)
