Pulse width calculation
Hello all,
I am currently working in LabVIEW 2019. I am trying to determine the pulse width or pulse duration of the incoming digital waveform through my cRIO. What are the possible ways to do so?
(1,953 Views)
If the input goes from false to true, keep the time in a shift register. If it goes from true to false, subtract previous time from current time. That's the pulse width in samples.
(1,948 Views)
Which c series card are you using??
You can find examples for pwm measurement in example finder.
CLD Using LabVIEW since 2013
(1,905 Views)
