Push button which gives data: how to store it?
this give me an idea how to do it... of course this is not the solution in fact
Carlos Ignacio Sarmiento
Electronic Engineer
(Ciudad Madero Technological Institute)
Laboratory of Bioelectronics, Biohospital Engineering Departament
National Institute of Neurology and Neurosurgery "Manuel Velasco Suárez" (Mexico City)
Message 11 of 19
(1,081 Views)
OK, here's one with a numeric control.
(I also implemented it as a solution with several buttons, but I still think an array of buttons is better)
Message 12 of 19
(1,078 Views)
Altenbach solution is a better one mine is not bad but his is more modulare and uses less event so there is not as much overhead. the biuld array can give you a little overhead tht is why I chose the insert into array function rather then the build array function. you could use the reshape array function and it should work like the biuld array function.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 13 of 19
(1,057 Views)
wow I see... it is a very good job!! thank you collegues. I have no much experience in labview, I'm learning by myself, ythat's why I'm asking you, I was two weeks with this little problem. Thank you so much to both!!
Electronic Engineer
Message 14 of 19
(1,054 Views)
The "insert into array" gives you the same overhead as the "built array" function. Both might force a new array allocation due to a change in array size. The most eficient way would be to initialize the shift register at the full final size with an impossible value (-1, NaN, etc. as suitable), then use "replace array subset" to fill with the real data without ever changing the array size again. 🙂
Message 15 of 19
(1,050 Views)
I have a last little problem, when I select a limit number and I finish my array, obvious, it is full, but if I select one more number (of push button) the sequence is erased... how can I avoid it?? I just want to store the sequence 🙂
Electronic Engineer
Message 16 of 19
(1,047 Views)
Which code are you using? Are you re-running the VI? In this case the shift regsiter gets re-initialzied of course. You could use an uninitialized shift register, for example.
Message 17 of 19
(1,045 Views)
the last one you published
Electronic Engineer
Message 18 of 19
(1,043 Views)
Try this (of course you would need to increase the max size number before re-running).
Message 19 of 19
(1,041 Views)
