Push-button wont activate
Hi again.
I'm glad that you have fixed the problem, however I really think you should consider your solution one more time and take a look at the state machine instead of using the Sequence Structure.
I found a pretty good forum post, that discusses State Machine vs Sequence Structure:
State Machine vs Sequence Structure for DAQ read/write and file I/O
http://forums.ni.com/t5/LabVIEW/State-Machine-vs-Sequence-Structure-for-DAQ-read-write-and-file/td-p...
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
Message 11 of 14
(891 Views)
Ah.. I see..
Thanks a lot for mentioning it.. I'll have a look at it, and see what it is 😃
Message 12 of 14
(878 Views)
I would love to check out the example, although i only have labview 11 and apparently can't open the file because it's made in 12 🙂
Thanks for mentioning state machines though.. It seems like a good idea
Message 13 of 14
(866 Views)
Here you go 🙂
Best Regards
Alex E. Munkhaus
System Engineer
Message 14 of 14
(861 Views)
