PushOK + TortoiseSVN + LabVIEW 8.6 source control is not working
Hi All,
Versions:
Windows XP + SP2
LabVIEW 8.6
PushOK 1.5.0.1
TortoiseSVN 1.5.2
I installed LabVIEW 8.6 and after that also updated source control software. When I try to setup source control on I get followed error messages (see attachments).  Does anyone else noticed these errors? Which module  cause these errors?
BR, Jim
(7,139 Views)
Have you talked to the folks at PushOK? Their software might not be compatible with the new version of LV.
 Mike...
Certified LabVIEW Architect
LabVIEW Champion
(7,104 Views)
Accepted by topic author SnowForest
(7,068 Views)
The ticket is marked private and not viewable.
George M
(7,057 Views)
I asked PushOK people to write solution also to here.
(7,045 Views)
Hi
I have the same error in other LabVIEW versions (8.5.1 and 8.2.1) on different computers with Windows XP.
I think I found some sollution for this error.
When you change in TortoiseSVN and in PushOK SVNSCC to use "_svn" instead ".svn". When I switch to "_svn" this error didn't show up.
Try this and write what it is working.
Maybe people from PushOK company write some sollution for this problem here or change the ticket open for public.
bogdani
(6,950 Views)
