Put Picture in Display Message.vi
hi, i wanted to know how to put a picture inside the dialog popup..
i know that i have to edit the subvi, but i tried looking at it and i have no idea how to do that..
can you show me by examples
Krispiekream
Message 11 of 21
(2,813 Views)
Krispiekream
Message 12 of 21
(2,813 Views)
Hi krispiekr…,
if you only want to show a picture in this vi, you can insert it by drag and drop. If you want the picture in the control among the text you can use the ActiveX WebBrowser component. Hope this helps.
Mike
Message 13 of 21
(2,810 Views)
i tried dropping the picture in the front page, but everytime i run it.
only the message show and not the picture..
Message Edited by krispiekream on 04-07-2008 04:24 PM
Krispiekream
Message 14 of 21
(2,800 Views)
You are trying to make the image appear in the pop dialog?  Dropping a picture on a text control doesn't make it miraculousy a part of the text.
What you will need to do is to create your own subVI that is a popup dialog.  Then you can place the picture on its front panel.  If you want the picture to change between different calls, then you put a picture indicator on the popups' front panel and pass the picture image to it by a connector on the subVI's connector panel.
Message 15 of 21
(2,786 Views)
sure, how would i do this
"create your own subVI that is a popup dialog"
thanks
Message Edited by krispiekream on 04-07-2008 07:51 PM
Krispiekream
Message 16 of 21
(2,782 Views)
Drop in this as a subVI (LV8.0).  Wire up your messages, button names, and your picture.  If you leave any of these blank, it will return the defaults.
Message 17 of 21
(2,774 Views)
wow!!!
nice!!!
its so easy when you do it..
thanks!!!!
Krispiekream
Message 18 of 21
(2,762 Views)
Hi krispiekream,
it's often easier when other do your work...Smiley Wink
To set up a (sub)vi as popup dialog you have to change it's properties (right-click the vi icon, window appearance)...
Please take those courses! They only take a day to absolve but will save you a lot of time afterwards! Smiley Wink
Message 19 of 21
(2,754 Views)
Ravens Fan,
can you save it as version 7.0?
Krispiekream
Message 20 of 21
(2,724 Views)
