Put informations in clusters with for loop
Hello everybody,
I will try to explain my problem.
I have X clusters in a cluster or a tab control or just in front panel (it could be adaptable for the most efficient way).
Each cluster had the same composition :
 - 2 delta numeric control ("delta min"/ "delta max")
 - others controls not useful for my problem (reference value, value min/max...)
I have an Excel file with all min/max delta for the X clusters.
I separate in 2 arrays my min max delta, but now I would like with a for loop fill in each delta numeric control for all clusters. I replaced the excel file by 2 random arrays.
So, in fact, at the beginning of my for loop, I have :
- 1 "delta minimum" array (with x values)
- 1 "delta maximum" array (with x values)
- 1 [cluster/tab control] of clusters (with x clusters)
The arrays and clusters are in the same order.
Could you help me to fill in the different clusters ?
You could delete the big cluster if the solution is easier without.
Thanks in advance,
Florian
(2,832 Views)
Hi Florian,
two notes:
1. as your clusters all look the same you should use a typedefinition for them
2. I want to recommend a different scheme for storing/handling your data: create an array of clusters! Either keep the names/labels of your current clusters in a 2nd array (of strings) or add the label as string into your current cluster. Then you can easily autoindex each cluster to fill in the delta values…
Side note: the data structures for storing data in the program doesn't need to be the very same you use for displaying those data to the user!
(2,828 Views)
Thank you
(2,813 Views)
Hi Florian,
(2,789 Views)
Hello
(2,761 Views)
Accepted by flabastie
Hi Florian,
(2,756 Views)
Hello GerdW,
You begin to know my Labview code and I need again your help.
My project is in good way, but I have again some troubles :
- I want for each cluster to color in red the min/max error counter if an error occurs. I already did that, but with the typedef, I don't find the good way for this coloration.
- If an error occurs, I have to log the error with all datas of the cluster. An error occurs when i want to write in my file. The file is well created with the option "open or create", but when i want to write ... error.
After this two problems, i think a very big part of the code will be ok.
Thanks for your help,
Florian
(2,733 Views)
