Put placemaks with GEplugin on google earth
Hi ,
I'm try to put some placemark on GE with GEplugin but no sucsess.help needed.
here is my code useing labview 2011.
thank's.
(2,797 Views)
I was able to run the VI, but did not receive any errors. Did you?
What do you expect this VI to accomplish?
Are you sure you're using the GE API properly?
Google lists a good amount of information here: http://code.google.com/apis/earth/documentation/
CLD Certified
(2,757 Views)
Hi Zach
Tanks for replaying.
I'm not receive any error for the vi .i just want to create/palce a place mark on GE.
not sucsess yet....
(2,749 Views)
Well, I don't see anything wrong with the LV portion of your VI, but I am unfamiliar with Google's API.
How do you know the placemark is not being placed?
I was unable to determine where is should be placed to look for it and GE did not go to the location on its own.
CLD Certified
(2,731 Views)
