Putting frontpanels of sub-Vi's togeter on one Vi front panel
Hi guys,
How to put the frontpanels of my sub-Vi's to one Vi frontpanel? So they are collected at one panel.
Message 1 of 10
(4,310 Views)
It called a Sub Panel
Omar
Message 2 of 10
(4,303 Views)
Tnx Omar, And how to use this sub panel?. How I get in a frontpanel from a sub Vi?
Message 3 of 10
(4,275 Views)
In LabVIEW, go to Help >> Find Example... and search for subpanel.
Examples are otfen a good source.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 4 of 10
(4,267 Views)
I don't know how comes the first line was duplicated a few times... not intentional.
Epictetus
Antoine Chalons
Message 5 of 10
(4,263 Views)
Epictetus
Antoine Chalons
Message 6 of 10
(4,263 Views)
@TiTou : I wish my kudos get duplicated like your posts.. LOL..Smiley Very Happy
Message 7 of 10
(4,240 Views)
See an example; I use the 'load and run.vi', I think you have it or it is available somewhere.
If the subvi is in the same dir as the calling VI, you can use this code.
The position property node is for changing the positition in the subpanel.
The code is a bit sloppy but I hope you get the point
Message 8 of 10
(4,228 Views)
Awhile back, I wrote a short tutorial, with example code, on how to use subpanels.  You can get it here.
Message 9 of 10
(4,210 Views)
Tnx, good advice here, I will look into it....
Message 10 of 10
(4,191 Views)
