Pwm generation with NI9401 and DAQmx (Labview 8.5.1)
I would like to build a variable pwm generator for a motor test (for work purposes) using a channel of NI9401 (the module is inserted into the chassis NIcdaq-9178 (I work with Labview 8.5.1).In order to set-up the module,  I have followed the following tutorial: http://digital.ni.com/public.nsf/allkb/0892C8D55C6D0C0E86257585004FD0B0   However, I have not found in Labview 8.5.1 the option in order to set NI9401. Is it possible to generate a PWM signal with this equipment?
Another question. I would like to change automatically every 0.2s the duty-cycle (the signal has a period of 20ms). Could you give me some hint for this operation?
Thanks in advance
(3,551 Views)
Hello gmarocco,
it may be a problem of driver. Which DAQmx driver do you have installed in your computer?
Concerning the changing of duty-cycle, you can do it using a while loop with a timing of 0.2 s and each iteration you have to change the time period in which your digital signal stays high.
Kind regards
(3,517 Views)
PS: check out this document, it could help you to find out how to change the duty-cycle while while your application is running.
http://digital.ni.com/public.nsf/allkb/82C9F3C15F62974E86256EBA0058CAF5?OpenDocument
(3,505 Views)
Anyway, you cannot following the procedure you linked, this is referred to cRIO not to cDAQ.
(3,492 Views)
Thanks, I  am using  NI-DAQmx 9.0.2
(3,479 Views)
Can you use your cDAQ with this version of drivers?
Anyway you cannot use this procedure since it is valid just for cRIO devices, not for cDAQ.
(3,475 Views)
