Pxie-4081 - Error - 1074117752
As mentioned in the title I am running a code that measures current waveform at different frequency. I set up the DMM rate to be 10x faster that the frequency studied. After all current were measured according the list of frequency, the code wait 1h and then redo all measurement.
My issue is that after several hours around 10-12 h of run, I get the code Error - 1074117752 as see on the attached picture.
Does anyone know what should I do to solve it ?
Thanks in advance for your help
Message 1 of 1
(1,404 Views)
