Python Session Error 1672
Hello everyone,
I'm getting the dreaded Error 1672 when trying to use 'Open Python Session'. Even the example vis (such as PythonNode_AddTwoDoubles.vi) are giving me the error right at the start, so it's not my implementation.
I'm using LabVIEW 2024 Q3 and Python 3.8.10, which should be compatible: Integrating Python Code in LabVIEW - NI
Python itself seems to be working fine independently, and the python version called (3.8 or 3.8.10) and the path to the .exe don't seem to be the issue, since changing them to something else gives different errors.
Any advice would be appreciated.
(1,198 Views)
@Ccccc wrote:
Hello everyone,
Did you check these things?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DlMtCAK&l=en-US
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
(1,181 Views)
