Python execution issue
I have stumbled upon an interesting issue while executing a Python script on LV2019SP1.
I basically have a script that should execute every hour. I created a Python class where in Create I store all the information about the script I am gonna run and create Python session that I will use in the loop (all as object attributes).
When the time comes I get the data from the object and execute the script
No errors are thrown but the return data is identical every time I run it. I compared the script output generated by LabView with the output I get when I run the script from command line. The script works fine and data on the other side is being updated too.
I have also tried to create the session before the loop and close it afterwards - no success.
The only way around it was to create/close Python session in each iteration.
Has anyone encountered problem like that?
Regards
(3,020 Views)
Hi Nicklasson, could you provide the Vi and python script you are using so we may reproduce and make a workaround for it?
Best Regards,
Soo Kin Wah
Technical Support Engineer
NI
(2,898 Views)
