[Q]: Has anyone written a Lock-In VI or knows how to so?
Hi folks,
I was wondering if anyone has written a Lock-In VI or knows how to so. I am
planning to lock-in a signal at 100Hz max. I will have a programmed
reference signal (programmed in LabVIEW and output via one of my D/A
outputs), and a measured signal in response to that.
I am grateful for any hint. Thanks in advance, David.
(2,537 Views)
Yes:
Scientific Consulting
Pierre-Alain Probst
En Gourze
1603 Grandvaux VD
Téléphone 021 781 28 80
Fax 021 781 28 53
scientific.consulting@worldcom.ch
Contrary to all appearances, it is not so simple, so I suggest you to contact
him.
(some problems are due to latencies of the OS, and to delays between the
measured signal and the programmed reference signal)
Patrick
Patrick Maillard
Institut de Recherches Robert BOSCH SA
PO BOX 12, Route de Denges 2
CH-1027 LONAY, SWITZERLAND
phone: ++41 21 804 72 17
fax: ++41 21 804 72 05
e-mail: Patrick.Maillard@ch.bosch.com
David wrote:
>Hi folks,>>I was wondering if anyone has written a Lock-In VI or knows how
to so. I am>planning to lock-in a signal at 100Hz max. I will have a programmed>referenc
e
signal (programmed in LabVIEW and output via one of my D/A>outputs), and
a measured signal in response to that.>>I am grateful for any hint. Thanks
in advance, David.
(2,537 Views)
