Q - How to program the min/max values of an intensity graph
Hi LabViewers,
I'm looking for a way to program the min/max Z values of an intensity
graph for image display properly, but unable to figure it out so far.
Any idea?
Chengye
(2,603 Views)
Right click the graph's control on the block diagram and create a property node.  Right click the node and Change all to Write.  RIght click the node again and select from Properties either the combined ZScale->Range->All elements  -or- you can individually define 2 property nodes for Max and Min (also under Zscale->Range).
Message Edited by Jonnie 5 on 12-14-2005 03:07 PM
2006 Ultimate LabVIEW G-eek.
(2,599 Views)
