[Q] How to set the sampling rate separately?
I'm using LV5.1 in Windows98 with SCXI-1200.
I want to set different sampling rate in each input channel.
I've ever used "AI acquire waveforms.vi" only.
Anybody can help me?
Example codes are highly appreciated.
Hyun-ho Lee
hhlee@hhi.co.kr
(2,808 Views)
The inputs of the SCXI-1200 are multiplexed to a single Analog-to-Digital converter. Because of this, the only difference in sampling rates that are achievable would be integer divisions of a common high frequency. This is functionally identical to acquiring all channels at the highest rate, and decimating (throwing away) data from channels that need lower data rates.
(2,808 Views)
