Q: I2C-BUS ON DIO-PINS
Has anyone done sonething like this already ?
I´m going to use an I2C-bus driven device and have a 6111 in my system.
This should work with 2 or 3 of the 8 DIO-Pin´s.
Do you have any hints or similar VI´s ?
Any help is welcome.
Jörg Boesler
jboesler@lenord.de
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(5,527 Views)
Hello Mr Boesler,
in general this should work.
Did you already have a look on the examples in LabVIEW? (Klick help --> find examples and enter i2c as keyword)
You´ll find some examples...
Is there something useful for you? What kind of application do you want to implement?
Nina | Applications Engineering | National Instruments
(2,485 Views)
Hello Mr Boesler,
I was thinking about this thing again.
So, to implement something like that is very complicated and probably won´t work.
I´ve found a KnowledgeBase for you, where you can read something more about that.
http://digital.ni.com/public.nsf/allkb/7A82E998C9225188862575BE0011C369?OpenDocument
Best Regards
(2,471 Views)
