I have recently started compiling C code using LabWindows/CVI, and have successfully called a simple DLL function from within LabVIEW.
I have a question about the types defined in LabVIEW's extcode.h file:
These are defined to explicitly quantify the number of bits used for each data type (e.g. float64 instead of float) in order to eliminate ambiguity across compilers.
When I am using LabWindows/CVI to compile, do I need to use the LabView numeric types defined in LabView's extcode.h, or can I use the standard C types (int, float, etc.)?
Is there a distinction between having to use these special types for CIN versus shared library calls in LabVIEW?
in advance,
Frenk
