Q: Parsing an IAK file in LabVIEW
I am looking for a way to read the fieldpoint channel names in their real order (not sorted) _and_ their corresponding range settings from an IAK file. Hardware is a FP-1001 network module connected via RS485 and a handful of AI-110s and AO-210s.
Has anyone found a way to do so yet?
Tried the FP get configuration info VI without succes, it sorts the channel names alphabetically. Edited the VI (threw out the sort array funktion), but no success: Channels now are mixed in no sensible way (the documentation confirms this behavior).
For the ranges, I've looked at the optomux !E, but a) it needs a FP ressource connected (can't work offline this way), and b) I have no clue yet of how to match these ranges with the well-mixed channel names 😞
Maybe someone here can help?
Yours, sincerely,
Sebastian F. Kleinau
(2,867 Views)
hi there
there's an activeX object MXCTRLLib.ImxConfiguration which lets you read the contents of MAX. I never worked with that but it looks quit good (see attachment)
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,856 Views)
I don't think that the ActiveX control exposes the necessary methods and properties to be able to read the range of FP-items. But there is another way to do that:
You can use Logos to get the info you need. You use the Datasocket Read.vi in LabVIEW and use the Logos connection URL (ex. lookout:\\10.0.34.183\FP\1TC\00\ConfiguredRange) to get the data. If you have LabVIEW 7.0 or later it is even easier... Follow these step-by-step instructions:
1) Open a new VI and place a Numeric Indicator on the front panel
2) Right click on the Numeric Indicator and select "Data Operations >> Datasocket Connection"
3) Click the "Browse" button and select "Browse Measurement Data"
4) Type in the IP address of the FP controller and press the "Refresh" button
5) Navigate to the Attribute you are intersted in (ex. FP>>1TC>>00>>Attributes>>ThermocoupleType) and press the "OK" button
6) Click the "Attach" button
7) This will allow Datasocket to read from the location specified (ex. lookout:\\10.0.34.183\FP\1TC\00\Attributes\Thermocoupletype) and populate that data into the Numeric Indicator.
8) I found I needed to put a while loop around the indicator with a loop delay and stop button to get any good data out.
*** The data you get back will be the code for the values... You will have to just experiment to see what value means which attribute. However, this will allow you to get the data. You can also cut and paste the URL you get from steps 1-5 into the URL input of a Datasocket Read.vi instead of using the Datasocket attach shortcut I do here...
Jochen Klier
National Instruments Germany
Message Edited by Jochen on 09-02-2005 08:34 AM
(2,839 Views)
