Q: Plug In 'Image':control requires an external library
I've had to move to LV7.1.
Because the IMAQ support isn't taken automatically from the LV7.0 installation, even if it hasn't changed, I have find and then followed the page:
http://digital.ni.com/public.nsf/allkb/B23E67C08CBD161886256F82007D58D8?OpenDocument
From the Missing LabView VIs, I could apply the point 4. (Note: The obvious point 3. didn't work, because when I tried to reinstall the drivers, I could only choose to update LV7.0 but not LV7.1, that missed from the drop-down list).
Even if I have moved everything that is described under the point 4., I still get the error mentioned in the subject line.
Which is the external library that is required and where can I find it?
Subsequent question, for the LV support only: couldn't the name of the missing library and its expected location be directly displayed in the error list?
TIA.
Victor
Message 1 of 1
(3,147 Views)
