Q - tcp/ip
I haven't used Labview for major projects -I have the following question:
is there a driver for Sound Blaster compatible soundcards? What I need to
do is sample (low sample rates) an analog sound signal and
a. simply plot the waveform
b. Send the data over tcp/ip (or via HTTP protocols?) to an internet-connected
PC running Labview and plot the data on the second screen.
Is this possible with the new versions? Anyone done something similar already
and can supply me with a solution?
SD
(2,960 Views)
Buy labview 5.1 and you have all that you need
Click here for Free Video!!
http://www.gohip.com/freevideo/
SD wrote in message news:38caef48@newsgroups.ni.com...
> Hi,
internet-connected
already
> Thanks
> SD
(2,960 Views)
