QD: Alphabetize Case Structure Cases
@Darin.K wrote:
Are you going to extend to Event Structures?
Had planned on doing this before posting but I have been unable to find "FrameNames" as an event structure property. It does have the "Rearrange by index" method though, so it would be very easy to do using the same logic with a different cast. If you can point me to the Frame Names array for an event structure, I will add it ASAP
Message 11 of 23
(2,221 Views)
Ah, bit of an oversight to not have those labels available. I think Jim (jcarmody) has an interesting hack to pull it off, perhaps he'll point you in that direction.
Message 12 of 23
(2,211 Views)
I'm sure you'll find this "interesting" - http://lavag.org/topic/10930-how-to-i-get-the-cases-in-an-event-structure/ 😉
___________________
Try to take over the world!
Message 13 of 23
(2,197 Views)
...and if y'all don't think that using OCR to try to read the text from a captured image of the node is *quite* the most elegant solution, please go vote for this idea on the Idea Exchange:
Configure Event Case with Scripting
Message 14 of 23
(2,192 Views)
Here's the post with my "final" product.  It works, but there are some letter combinations that get missed.  It certainly is not an elegant solution, but it's all I could come up with.  Let me know if you plan to follow that rabbit and I can post my updated "brute force" OCR stuff.
It's really not elegant...
Jim
Message 15 of 23
(2,176 Views)
Brute force never is 🙂
Message 16 of 23
(2,155 Views)
Holy smokes, Jim. After looking at the code that really is a very outside-the-box and unfortunately necessary way of doing it. Hopefully future LabVIEW releases will make this easier. However, a lot of work clearly has gone into that by you and you deserve more Kudos than I can give.
Message 17 of 23
(2,148 Views)
Considering the location of your help, is it really surprising that the result is not elegant?  Smiley Wink
Spoiler
Actually I rather enjoy the OCR solution, it's just crazy enough to work all it takes is someone crazy enough to try.
Message 18 of 23
(2,137 Views)
@Darren wrote:
... y'all...
*Cringes*. Despite two years in Dallas, after living in Chicago all my life, I still try and avoid this contraction. Although, admittedly, sometimes it tries to slip out, I still consciously use "you guys". I refuse to convert Smiley Tongue.
Anyways, back from my tangent, I kudo'd the idea.
Message 19 of 23
(2,129 Views)
@for(imstuck) wrote:
*Cringes*.
Funny.  I've lived all my life in Texas, so "you all" and "you guys" make me cringe.  😉
Message 20 of 23
(2,122 Views)
