QNaN
LabVIEW experts,
I have a math question about QNAN and typecasting.  I have written code that will take a hex string and convert it to a floating point number.  For example:
hex: 0000C0C3
I swap the bytes to get it to C3C00000, integer value 3284140032, and then typcast it using 0.00 as the type.  When I come across hex strings which evaluate to negative numbers, such as 0000C0C3 and after I swap the bytes and typecast, I get -384.  Using this same procecdure in C++, I get 1.#QNAN00.  How does the LabVIEW type cast subvi actually work?
(4,982 Views)
LabVIEW typecast does already a byte swapping on the Intel CPU platforms so if you byte swap again you are back at the original byte order. On C a typecast is really just a reinterpretation and no byteswapping takes place.
Rolf Kalbermatter  My Blog
(4,977 Views)
Reading my question over again, I don't think I explained my question to well.  If I take 0000C0C3 as a string, pass it to the "Hexadecimal String to Number" subvi, I get an integer value of 49347, which I typecast to a double for a final value of 6.91499E-41.
If I swap the bytes of 0000C0C3 to C3C00000 and repeat the process, the "Hexadecimal String to Number" subvi returns an integer value of 3284140032, which I typecast to a double for a final value of -384.
The typecast subvi help file says it returns the value as *(type*)&x.  When I use this same procedure C++, it works for all positive numbers, but I get a 1.#QNAN00 error on negative numbers.  I'm just trying to understand how LabVIEW typecasts the negative numbers.
(4,967 Views)
Accepted by topic author shivels
Hi shivels,
what happens when you typecast to a SGL (as you have a 4 byte number) in both LV and C?
Typecasting means reinterpreting a byte stream. 0xC3C00000 represents an U32 = 0d3284140032 or an I32 = -1010827263 or a SGL = -384. All use the same binary representation, just their interpretion is different...
(4,962 Views)
Gerd you saw what I had overlooked! Smiley Happy int32 cating into a double has to cause trouble. In C you can't do that as the higher 32bits are simply undefined. LabVIEW does a bit different. Seeing that the target needs a longer memory block LabVIEW appends the required 4 bytes of 0 to make it big enough to cast to a 8 byte double.
(4,959 Views)
Thanks guys thats the info I was looking for.  I kind of thought LabVIEW had to be doing something funny, but wasn't sure.  Now I'm off to try and figure out how to prevent the 1#QNAN00 in my C++ code.
Cheers,
Shivels
(4,948 Views)
