04-28-2011 03:41 PM
Hey,
I am planning to implement a quadrature digital downconverter on the FlexRIO PXIe 7965R (Virtex-5 FPGA) module. I was wondering if there was an IP from LabVIEW to implement a QDDC. I have an ADC (NI 5761) that sits on top of the FPGA module.
The purpose of the QDDC is to implement a scope on the instrument. My operating frequencies for the DUT are going to be less than or equal to 10 MHz. I was also wondering if there is something other than a QDDC that might be better suited to this range of frequencies.
Tanuj
05-03-2011 03:36 PM
Hi Tanuj,
Unfortunately, I was unable to find any IP in LabVIEW for implementing a QDDC on FPGA. You can check this web-site for other possible IP's that may be helpful to you. www.ni.com/ipnet
05-27-2011
05:40 PM
- last edited on
10-15-2025
04:15 PM
by
Content Cleaner
Hi Tanuj,
I've got an update for you concerning this issue. Since the FlexRIO FPGA modules use Virtex-5 FPGAs, you should be able to use the Xilinx CORE Generator to create the IP needed to meet your needs.
Linked below is a great article outlining the development process of creating DDCs for a FlexRIO device. Also linked below are some links to tutorials on our website illustrating using External IP with LabVIEW FPGA.
- EETimes article on the development process for DSP IP with LabVIEW FPGA:
http://www.eetimes.com/design/programmable-logic/4211353/Building-FPGA-based-digital-downconverters-...
- Importing External IP into LabVIEW FPGA:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0jiCAA&l=en-US
- Integrate External IP in the LabVIEW FPGA Module using IP Integration Node
http://zone.ni.com/devzone/cda/tut/p/id/10015
