Quality Print
You can get the EPL code from within ZebraDesigner.  Design your label and confirm that it prints properly.  Go into the print dialog and tell it to print to a file.  It will convert your label design into EPL code which you can then copy to the printer, as detailed above.
If you want to use ZPL (rather than EPL), you'll have to figure that out on your own.  EPL is sufficient for my purposes.
aputman
Message 11 of 15
(1,732 Views)
You can do the same thing with designer to get the ZPL. Personally, I just create my ZPL directly in an editor. It is not too hard once you get the hang of it.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 15
(1,730 Views)
@Mark_Yedinak wrote:
...or I can see if I can package up our code which uses the Zebra SDK.
I assume the SDK requires a subscription?
aputman
Message 13 of 15
(1,729 Views)
No, it is available for free: https://www.zebra.com/us/en/support-downloads/printer-software/link-os-multiplatform-sdk.html
It appears tha the moment I can't easily post our code. We have switched to using PPLs and there are a few dependencies that would get pulled along since this code is part of a much larger framework. However, I do know that calling the SDK is pretty straight forward.
 I'll see if I could put together a smaller example.
Mark Yedinak
LabVIEW Champion
Message 14 of 15
(1,727 Views)
Sorry, was in Holidays for a week..
The sharing is described here very well: https://supportcommunity.zebra.com/s/article/Print-RAW-File-From-CMD?language=de
I design my labels all the time with this lightweight tool: https://zpldesigner.com/
Message 15 of 15
(1,664 Views)
