Quality warning on data binding
Hi
When viewing these variables in the VI ,the boolean with shared variable lights up green, but it showing "quality warning on: [local address]" when I run the code and if i stop services also it is showing green light instead of red. I uninstalled and installed the OPC server still it is showing the same error. Can i know why and how to solve?
I attached status of data blinking.
Nikitha
(2,504 Views)
@Niki_chinni wrote:
When viewing these variables in the VI ...
Fix the "variables in the VI".  Which variable?  I'd guess the fourth one, but if you had attached your VI (not a picture of the VI, but the actual file with the ".vi" extension, or if it is part of a larger LabVIEW Project, the entire (compressed) Project folder (as a .zip file), making sure we know which VI shows the error.
Otherwise, we are all just "guessing" ...
Bob Schor
(2,494 Views)
With the shared variable. In my local server it is working fine after creating EXE and deployed in someother server it is showing quality warning error and also if i close opc server and services green line is not changing to red.
(2,453 Views)
Ahh, yes, I didn't see it in the VIs you failed to attach.  Sorry I can't help you, my Extra-Sensory Perception isn't working (I think CoVID-19 is to blame).
Bob Schor
(2,438 Views)
Bob Schor
Lost your sense of code-smell?
Bill
CLD
(Mid-Level minion.)
(2,435 Views)
