Quasi random number
How do I create Quasi random number using LabView ?
Is there any module for Labview ?
Somebody help!
thanks,
(4,278 Views)
Can you not use the random number generator from the numeric palette -- the icon that looks like a couple of dice?
(4,253 Views)
For the sake of being redundant and providing a visual Smiley Wink
It's found in the Numeric palette
Message Edited by Steve.Briggs on 11-21-2007 09:55 AM
(4,244 Views)
Hi karthik,
apart from using built-in random number generator you can also use this. It will work on PC too.
(4,227 Views)
Well, a single quasi random number is not really different from a (pseudo random number), the difference arises if you have a sequence of such numbers.
http://mathworld.wolfram.com/QuasirandomSequence.html
http://en.wikipedia.org/wiki/Low-discrepancy_sequence
(http://www.google.com/search?q=quasi+random&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&s...)
I am not aware if LabVIEW has such a beast.
The web has many code examples, so all you need to do is wrap it into a DLL. 🙂
http://www.google.com/search?q=quasi+random+code&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UT...
Message Edited by altenbach on 11-21-2007 08:55 AM
(4,216 Views)
Or you can just do this:
Here's the equivalent LabVIEW code:
Of course, if you only want a quasi-random number, you can't use this as it's truly random.
___________________
Try to take over the world!
(4,192 Views)
Mathscript has two functions that may help:
Richtmeyer and Halton
These are not currently exposed in the LabVIEW palettes
-Jim
(4,169 Views)
