Qucik Graph Cursor Legend Questions
Hi all, I have a couple of quick questions regarding my graph cursor legend: 1. Is it possible to move the position of the cursor legend during runtime? I cannot seem to drag it around the graph? 2. Can I hide/remove the cursor mover? This is not needed and is for this vi as I need to be able to manually drag the cursors only. I am accessing the cursor legend during runtime through a right-click and selecting "visable items:. Thanks, Jack
(2,965 Views)
Hi please check Using Cursor Legend in this link if it is helpful
https://www.ni.com/docs/en-US/bundle/labview/page/customizing-graphs-and-charts.html
Sorry i don't know exact answer for questions, But did you try property node of Cursor.
-To access it, right click the graph indicator in Black Diagram and go to create>>Property Node>>Cursor.
-Lot of options regarding cursor available there, you can make selected property to write or change the parameter. and check this for help on cursor properties
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/properties-and-methods/vi-server/generic/c...
uday
(2,918 Views)
