Query Related To GOOP
Help for GOOP
I want to do something like this in GOOP can some body help me out
1. when i create an instance of my object it should have one property (Say "Name")which should be different for each instance
2. i want to have one more property (say "all instance Names"). when i read this property it should give me array of string which will contain the "name" property of all the instances that are currently in memory
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
(2,792 Views)
If I were doing this I'd create a separate class that's a collection class of your objects that you can use to list your objects, add/remove, etc. That would be more in-line with OO principles.
(2,788 Views)
Smiley Very HappyThanks a lot
Tushar Jambhekar
(2,785 Views)
