Query for Tab Control
Hey everyone,
I am working on an application which need a Tab Control in it. I have 2 Tabs in that control. One is Engineering mode and other is Application mode. Only when certain condition's are met in Engireeing mode then only user can change to other mode by pressing the tab's .....
I hope you got wht I want. for any further clarification please let me know
thanks
Sarang Dhananjay Jaiswal
Satyam Development Center, Banglore, INDIA
Message 1 of 8
(4,119 Views)
Sarang,
I think you want to disable the Tab control until certain conditions are met. I just did this for my current project. Here is a test VI that I put together to find out how it could work.
Lynn
Message 2 of 8
(4,108 Views)
Nice post Lynn!
You taght me something with the array to cluster >>> Unbundle by name construct.
It looks like this got introduced in LV 7.0 and I nver noticed it. It figures that I am still learning about LV 7.0 and LV 8.0 is announced.
Thank Lynn.
Ben
Message Edited by Ben on 10-01-2005 11:02 AM
Message 3 of 8
(4,096 Views)
Hey thanks for the wonderful suggestion.I used it in my program as its working fine now. I have few more quiries about Tab Control.
I have 3 Tabs (Tab_A, Tab_B, Tab_C) in Tab control. Each Tab contains one While loop. Now if i run my program and click on the Tab_B then the controls in Tab_B is not active because the program is still in Tab_A's while loop.
What I  want is as soon as the user clicks on the Tab_B or Tab_C the current while loop (in this case Tab_A's while loop) should stop.
I hope you got what exactly I want. Please let me know if you need more clarifications.....
Thank You.
Message 4 of 8
(4,039 Views)
Hello Sarang,
just check the tab control in your while loops and connect this with your normal stop condition with an OR or AND operation.
Example: in whileloop "A" you should have a statement like this: IF (tab<>"A" OR stop_condition) THEN stop_whileloop
Message 5 of 8
(4,035 Views)
hey GredW,
 I am not able to figure out what you explained ..... it would be nice if you could explain me with some example vi....
Thank You.
Message 6 of 8
(4,019 Views)
Hello Sarang,
maybe a picture says more than words 🙂
Message 7 of 8
(4,009 Views)
You should consider the fact that you don't "need" a seperate loop for each page (unless your logic calls for it). If possible, you should handle all the user interface elements in a single loop - when the users can't see page A, they can't use the controls in it either.
___________________
Try to take over the world!
Message 8 of 8
(3,991 Views)
