Querying number of channels on a device
How can I ask programmatically, "Dev0, how many analog output channels do you support?"
(2,825 Views)
It would depend on the device. I would look at the manual for the device you are using and see what what it's API is. As written no one can give you an answer since it all depends on what you are talking to.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,819 Views)
(2,817 Views)
JB wrote:
I stand corrected. Will this work for all devices?
Mark Yedinak
LabVIEW Champion
(2,813 Views)
Forget to mention the path to this property node :
Functions palette >> Measurement I/O >> NI-DAQmx >> Advanced >> System Setup >> Device Node
or easier and faster (LV8.6 and later) : Ctrl+Space to show Quick Drop >> type Device Node >> select DAQmx Device Property Node
(2,811 Views)
I expect it to work with all DAQmx devices but (obviously) I haven't tested it for all of them...
(2,808 Views)
