Question: How to make a radar simulation on XY Graph?
Just uncheck the "Erase First" to stop flickering
Message 11 of 52
(6,533 Views)
Couldn't resist either Smiley Wink
Message 12 of 52
(6,509 Views)
Friday Night Fun - Now with Sonar Sound (though radar <> sonar).
Message 13 of 52
(6,479 Views)
Message 14 of 52
(6,467 Views)
Is there anyway to remove the scale (numbers), but leave the grid?
=== Engineer Ambiguously ===
Message 15 of 52
(6,460 Views)
Remove the yellow marked wires in "draw polar grids.vi"
Message 16 of 52
(6,445 Views)
Be careful!
You will be modifying a VI in vi.lib. Better to clone off the VI as a new name then make the edits.
Ben
Message 17 of 52
(6,432 Views)
@altenbach wrote:
A real radar simulation might need an intensity graph, showing the radar echo intensity as a function of direction and distance. You could simulate a 2D world with some objects and given radar reflectivity, the canculate the profile for each direction.
Here's how this could look like. Modify as needed. 😄
(Ships are static but could easily be animated inside the main loop if desired.)
Message 18 of 52
(6,418 Views)
Reminds me to my mil. service time back in the 80's being radar mechanic .. 🙂
The radar was all tube based, designed in the 60's, the deflection unit was mechanically turning around the CRT (in sync with the antenna)
Some more challenges:
Decay time should be longer....
The 'green' line shouldn't  be a line, just random noise on a lower level...
Greetings from Germany
Henrik
LV since v3.1
Message 19 of 52
(6,380 Views)
Would be easy to add noise. Decay can be prolonged by subtracting only every n-th iteration. Do you have a video of a real (not Hollywood) old radar screen?
Could also go to U16 for the display but I think 256 shades is plenty. 😄
Message 20 of 52
(6,371 Views)
